Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Material Data as a Function of Independent Field Variables › Reply To: Material Data as a Function of Independent Field Variables
October 3, 2024 at 1:59 pm
You are on right track with TBFIELD.
TBFIELD supports user defined variables (UF01 thru UF09). You can edit any initialized user defined field variable via UserFld subroutine. Please see Section 9.2.1 of the MAPDL Material Reference Guide as well as Section 2.4.14 of the MAPDL Programmers Reference Guide.
