Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Pressure and Thrust Distribution in Fluent CFD POST for a propeller › Reply To: Pressure and Thrust Distribution in Fluent CFD POST for a propeller
V.P
Since the polyline goes around the blade, there will be two values at the same axial position of the blade. You could use the axial distance as the variable for x axes.
I would suggest you export the pressure values along with x yand z values of the line using export feature in cfd post and then manually plot it outside for better control.
