Ansys Learning Forum › Forums › Discuss Simulation › Optics › Issue when evaluating Ansys Academic Research Optics License › Reply To: Issue when evaluating Ansys Academic Research Optics License
Niki Papachristou
Thank you for your clarification here,
Can I ask you to check if it is only the Performance Diagnostic window that shows this behavior or other windows lists only 4 cores (for example local optimization and tolerancing)?
I think one explanation for this is a corrupted installation file. In this case, I would suggest to re-install the software and actually try our latest version 2024 R2.02.
Let me know if that worked or you are still facing the same issue.
Kind Regards,
Niki
