Ansys Learning Forum Forums Discuss Simulation Fluids ansys aqwa : hinge connector Reply To: ansys aqwa : hinge connector
nhanani4
sorry i did not understand"the hinge joint local x axis does no longer parallel to the global X axis.
from my understanding, i put the hinged located at x-axis same with the origin x axis.
what to mean is the floating structure move so the connector is not it x-axis?
this is the dat.file show..what mean by the value, can i get the stiffness of connector in deck 12?
