maabbas
Hi Erik,
Thank you so much for your reply.
I’ve attached an image with the true scale to confirm the penetration issue between the spring and the bar.
Additionally, I ran several simulations, adjusting the spring stiffness, but it did not affect the displacement of the rod. This further suggests that the interaction between the rod and the spring is not functioning correctly.
Do you have any insights on how I can proceed to resolve this issue?
