Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error opening Workbench project › Reply To: Error opening Workbench project
Go into the folder listed in the path using File Explorer, and see what's there. Copy the contents somewhere safe and then see what can be opened. Also check disc space and access. Unless you're doing anything linked to parameters it's generally recommended to use Fluent in stand alone mode.
