Ansys Learning Forum Forums Discuss Simulation Fluids Particle count issue Reply To: Particle count issue
You're tracking parcels, each parcel follows the trajectory of the particle but has mass etc of the parcel. Check the DPM part of the manuals and possibly some background reading. Note, a parcel usually has significantly more mass than a single particle but that's not always the case. In Fluent particle is used incorrectly in place of parcel in many instances.
I don't know what your injection is set as, but you're releasing some parcels every flow time step. If it's a surface release from the inlet you're releasing a parcel for every facet on the inlet every fluid time step. That may explain the parcel count you're seeing. Â
