Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Thermal analysis using shell elements and midsurfaces › Reply To: Thermal analysis using shell elements and midsurfaces
			October 2, 2024 at 11:32 am
	Case 1: Using midsurfaces
Boundary condition
Mesh : Automatic settings
Result: It can be seen that there is hardly any difference in temperature even though all three materials are different
Case 2: Using solid bodies
Boundary conditions
Mesh: Automatic settings
Result: Here it can be seen that there is significant difference in temperature as per material properties.Â
Shouldn't midsurface case and solid case give same results? Please guide.
Thanks
 You are navigating away from the AIS Discovery experience
