Ansys Learning Forum Forums Installation and Licensing Ansys Products Transient Thermal-Electric system issue Reply To: Transient Thermal-Electric system issue
shaoxiang_go
Hi dlooman,
Thank you for your suggestion. I have changed the resistivity of material 3 to 100 like what you suggest. However, I am still getting a warning (even before changing the resistivity, sorry that I forgot to mention this earlier) :
"The coupled field analysis is weakly coupled and requires at least two iterations to achieve a coupled response. Try incrementing the number of iterations." - What does this mean though? I have tried searching this error online but nothing much was mentioned about this error message. Also, which part of the solution output should I look at since it is a document with many pages?. How do I allow the solution to be a transient one instead? Thank you very much.
