Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › licensing problem while using remote PBS cluster › Reply To: licensing problem while using remote PBS cluster
October 2, 2024 at 7:52 am
komanek
Finally I managed to solve this. Ansys workbench doesn't pass the license information to the remotely executed solver, not even the location of the license server. All the communication with the license server was from the workbench, while nodes tried to contact localhost. It was not obvoius from the job logs..
I had to create a file ansys_inc/shared_files/licensing/ansyslmd.ini manualy, since it is not created at the time of ansys installation (tested on two different linux computers), which seems was working better in previous versions of ansys.
