Ansys Learning Forum › Forums › Discuss Simulation › Fluids › No “Add FSI Data Transfers” in Coupling System › Reply To: No “Add FSI Data Transfers” in Coupling System
October 1, 2024 at 7:52 pm
After adding both Rocky an Mechanical .scp files
You need to add a Coupling Interface
And adding both Rocky SysC Wall and Mechanical SysC Region for the Side option
You should see this "Add FSI Data Transfer" option by right-clicking in the Coupling Interface
If you double-checked every step, I suggest you opening a ticket for Rocky Support.
best regards,
Lucas
