Ansys Learning Forum Forums Discuss Simulation Electronics WARNING: Coupled simulation restarted due to out of sync coupling cont Reply To: WARNING: Coupled simulation restarted due to out of sync coupling cont
Chunhui Zhang
Hi Alexia, The out of sync warning usually happens when the results are not available in upstream or downstream of the two-way coupling. Please try Results -> Clean Up Solutions in Icepak Ribbion, select the solution of the two-way coupling analysis or All solutions, make sure that you check Inlcude Linked Data checkbox and then click Do Deletions. Rerun the Icepak two-way coupling Analysis. The surface material is for radiation settings, it shouldn't matter to EM coupling.
