Ansys Learning Forum Forums Discuss Simulation Fluids Ansys fluent, regular waves Reply To: Ansys fluent, regular waves
The panel will contain everything, typically it's a wavelength and you set the speed in the first tab of the bc panel. If you're not seeing "good" waves check the mesh is refined sufficiently in both amplitude & wavelength and that the sky is a pressure boundary at a reasonable distance from the free surface.Â
