Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Can VISTA TF be utilized to do through flow analysis for axial compressor blade? › Reply To: Can VISTA TF be utilized to do through flow analysis for axial compressor blade?
October 1, 2024 at 9:34 am
12125090
Thank you Petros for your kindly reply. But I'm still wondering that if I want to do a throughflow anlaysis for a compressor stage, including a row of rotor and a row of stator, does it mean that I should create a TFExport for the two blades respectively in a same DesignModeler Module and then transform to VISTA TF automatically by connecting the modules?Â
