Ansys Learning Forum Forums Discuss Simulation LS Dyna Problem with working out the ICFD LS-Dyna model Reply To: Problem with working out the ICFD LS-Dyna model
Reno Genest
If you open the i.k file in a text editor, you will see at the top of the file that the units are g/cm/s and so pressure is not in Pa; it is in dyne/cm2. Does this make more sense?
https://www.dynasupport.com/howtos/general/consistent-units
Also, note that it is possible that these examples  use fictional material properties and loads. It is up to the user to user proper materials, loading, consistent units, etc.
Let me know how it goes.
Reno.
