Ansys Learning Forum Forums Discuss Simulation General Mechanical Mechanical scripting – coupling ACP and Ansys Mechanical Reply To: Mechanical scripting – coupling ACP and Ansys Mechanical
ErKo
Hi
It is possible to open a cdb with pyMechanical (2024 R2).
(this shows the commands involved - same can be used in pyMEchanical : https://discuss.ansys.com/discussion/4431/how-to-add-a-model-in-standalone-mechanical)
So you can do that.
There are possible other ways, but this is the most easy way and similar to the pyacp ->pymapdl example (example) that also opens up the cdb file generated by acp.
All the best
Erik
