Ansys Learning Forum Forums Discuss Simulation General Mechanical How to introduce viscous regularization parameter Reply To: How to introduce viscous regularization parameter
ErKo
This post has a similar topic (use the commands there):
https://innovationspace.ansys.com/forum/forums/topic/how-to-solve-convergence-issue-of-delamination-by-twisting/
Put them into an apdl command added under the Inter. Delamination object marked in red in the/your above image (use matid for MATID in the TB command so: TB,CZM,matid,,,VREG)
TB,CZM,matid,,,VREG
TBTEMP,22.0 ! Define first temperature
TBDATA,1,c1 ! Define damping coefficient at temp 22.0 change c1 as needed
Thank you
Erik
