Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › CONTROL_REFERENCE_CONFIGURATION › Reply To: CONTROL_REFERENCE_CONFIGURATION
September 30, 2024 at 9:32 am
Hello Alex,
Thank you for your response! I still do have some questions though.
Even if I set the number of iterations to 4, still only one iteration takes place. What could be the problem? What is the outputfile with the reference geometry, is that the iter1.guess file? Is the pressure curve applied the pressure due to which the stressfree geometry was deformed? Hope to hear from you!
Best,
Babette
