Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Minimize reflection to almost 0% › Reply To: Minimize reflection to almost 0%
jiglesi1
I resolved this issue and figured out I was adjusting the wrong dimension on the lnP film rectangle to change my reflection plots.  So does that mean once I get it closer to 0% reflectivity, the marker on the y axis in respect to the reflection will be closer to the 0 mark on the y axis correct? I am not sure what the y marker actually repreesnts since there are no units on it. This is also in respect to lambda at 1.5um. Thanks!
