Ansys Learning Forum Forums Discuss Simulation Fluids Trouble with importing a 3d .msh file from GMSH Reply To: Trouble with importing a 3d .msh file from GMSH
If it's a mesh file can't you just read the full volume mesh into Fluent? Otherwise try reading in the boundary mesh. Note, that will probably negate the use of the water tight workflow so you'll need to find the mesh objects in the tree and then volume mesh.
