Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Export the Full time transient data to Ansys CFD-Post › Reply To: Export the Full time transient data to Ansys CFD-Post
Federico
when you export or write solution data in Fluent, each file stores the data for a single time step. If you want to have data over several time steps, you will need to write multiple .dat/.cdat files.
You can set Autosave from the Solution tab to write your data at specified intervals over the course of your Fluent simulation.
