Ansys Learning Forum Forums Discuss Simulation Fluids Transient FGM (Ignition and Heat Release Rate) Reply To: Transient FGM (Ignition and Heat Release Rate)
Mathieu G
Hi Ren,
Thank you for your answer. I'll try with the Finite Rate/No TCI model.
Do you have any idea why i'm having a negative HRR when using partially premixed combustion models ?
Thanks !Â
