Ansys Learning Forum › Forums › Discuss Simulation › Optics › Question about FDTD simulation › Reply To: Question about FDTD simulation
September 25, 2024 at 5:34 pm
Without details about the structure/materials and settings I can only say that, for engineered material such thing can happen, since there might be some resonance or other physics that lead to such results. I would suggest you to check the if the structure and simulation settings are correct. for example periodic conditions and plane wave source should be used. Is the reflection/transmission normal?
