Ansys Learning Forum Forums Discuss Simulation General Mechanical How to set constrains on dependent variable ? Reply To: How to set constrains on dependent variable ?
Gary_S
Hello
Here is one idea:
In DM, you can create "dummy parameters"  then define geometry based on that dummy parameter.
Then in a DOE optimization, you can assign a range to that dummy parameter.
 It is done in the Parameter Relationships section.
Inline image 1
