Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › System Coupling Data Transfer Issue › Reply To: System Coupling Data Transfer Issue
Rahul
  • The System Coupling option must be selected on the desired moving and deforming wall boundaries in order to obtain displacements from other co-simulation participants taking part in the coupled analysis.
  • The via System Coupling option must be selected on the desired wall boundaries in order to obtain heat transfer data (temperature, heat flow, or heat transfer coefficient) from other participants taking part in the coupled analysis.
Check your Fluent settings. Provided correct settings and then you should be able to create required data transfer.
For more information refer: 49.5. System Coupling Related Settings in Fluent (ansys.com)
