Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › make mechanical analysis on topology result › Reply To: make mechanical analysis on topology result
Harshvardhan
You can use the shrinkwrap option to smoothen out features and then use smooth option.
For an example for Topology Optimization you kindly go through the following link:
Topology Optimization of a Bell Crank| Ansys Innovation Courses  
The example in the link covers the steps required to use the optimized geometry for further analysis.
Regards.
Harshvardhan
