Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Bonded contact failed in Modal Analysis › Reply To: Bonded contact failed in Modal Analysis
September 24, 2024 at 11:11 am
Hey,
Are you trying to conduct a pre-stress modal analysis ? If so you can use this link to know more about it here
https://innovationspace.ansys.com/courses/courses/modal-analysis-in-ansys-mechanical/lessons/how-to-perform-prestressed-modal-analysis-lesson-2-2/
If you are indeed using a prestressed modal can you share more info on the contact status before the modal analysis is performed ?
Thanks
