Ansys Learning Forum Forums Discuss Simulation Preprocessing Too High Aspect Ratio Reply To: Too High Aspect Ratio
Skew can't exceed 1.0 as it's 0 (perfect) to 1.0 (flat), so please check.
Re the aspect ratio. Think what the purpose of a boundary layer mesh is. So, I'd expect a high aspect ratio. This may be acceptable, but assumes the flow values don't change much (and do so slowly) along the inflated surface.
