Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › SpaceClaim Error Failed to Thicken faceted body › Reply To: SpaceClaim Error Failed to Thicken faceted body
September 24, 2024 at 6:22 am
How “dirty” is the model? When the triangles are fully connected and are not smooth, then adding thickness can result in non-manifold bodies. If the surface you are trying to thicken is smooth, then you may be able to use the skin tool. See below for an example.
https://www.youtube.com/watch?v=k5J260NepRs
