Ansys Learning Forum Forums Installation and Licensing Ansys Products After restarting, the shell elements on the exterior surface of the vehicle were Reply To: After restarting, the shell elements on the exterior surface of the vehicle were
mjmiddle
Does that mean you used External Model system to import? What application is this? LS-Dyna pre? Ansys Mechanical? Whag format is the file you imported? Were there errors or warnings? There will normall be messages when something in the impirt is skipped. Check the message panel in Mechanical and workbench.
