Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Variables not freed from memory after using the clear(); script command › Reply To: Variables not freed from memory after using the clear(); script command
Guilin Sun
I am not sure if this is a memory leakage. Fro this article: https://optics.ansys.com/hc/en-us/articles/360050995394-Getting-Started-with-lumopt-Python-API
the default setting is to store all simulation files:
: store_all_simulations: bool
Indicates if the project file for each iteration should be stored or not. Default = True
Please try to set it as "false".
in addition, since the mesh accuracy is fixed and the mini resolution is predefined, with more and more materials filling in, the finer mesh region might be larger and larger. The mesh size depends on the material refractive index. If the filling material occupies more and more space, mesh memory will be increased for simulated data (mesh and field data). This might be another reason.
