Ansys Learning Forum Forums Discuss Simulation Photonics Discontinuity at the boundary of the substrate and waveguide of AlN-on-sapphire Reply To: Discontinuity at the boundary of the substrate and waveguide of AlN-on-sapphire
Guilin Sun
It is correct, since now you are plotting the total field. If you only plot the tangential field components it will be continuous. In the normal direction it is the displacement field that is continuous.
