September 23, 2024 at 9:16 am
Mrinmoy Bharadwaj
Hello jaslam,
Assuming you are planning to use the Renesas component library inside Ansys Electronics Desktop 2024R2 , kindly do the following:
1. Download the Renesas component library from the link and unzip the contents.
2. Kindly coppy the contents of the "Bitmap" folder and paste those into
3. Kindly copy the other folder and paste it into
You should now be able to see the folder inside the "Component Libraries" under "System Libraries" in Ansys Electronic Desktop.
The process remains the same for older versions as well.
