Ansys Learning Forum › Forums › Discuss Simulation › Photonics › FDTD sample points in IR reflectance › Reply To: FDTD sample points in IR reflectance
Guilin Sun
You can increase the points to be recorded. and since you plot result vs wavelength, you should use "wavelength spacing".
or you plot result vs frequency.
Make sure the broadband is what you need exactly.
