Ansys Learning Forum Forums Discuss Simulation General Mechanical Coordinate System Aligned to Nodes Reply To: Coordinate System Aligned to Nodes
matt
I found the answer.  Select a node for the origin of the coordinate system.  Then under Principal Axis, choose Geometry Selection.  Then select the node at the origin, as well as the neighboring node for alignment.  The coordinate system will then be aligned to the two nodes.
