Ansys Learning Forum Forums Discuss Simulation Photonics Question about auto shutoff time Reply To: Question about auto shutoff time
Guilin Sun
If you use the default automesh with mesh accuracy 2 or higher, it should be ok. However, from what you said, it might be because the simulation time is too short. The default 1000fs is for optic frequency. at the THz range, the simulation time is much longer. Please check the source signal and see if it is a complete pulse without cutting off.
In addition, if you can read those posts it would be helpful:
为什么说仿真时间要足够长才能得到正确的频域结果
 One suggestion is to signficantly increase the simulation time, and let the autoshutoff min to terminate it.
