Ansys Learning Forum Forums Discuss Simulation Electronics How to calculate the power flow through a LumpedPort or LumpedRLC ? Reply To: How to calculate the power flow through a LumpedPort or LumpedRLC ?
dushyant.marathe
Hi Kai Ma,
For power loss analsys, you can define lumped port in HFSS for loss component such as Resistor and take the solved HFSS model into Ansys Circuit.
Inside circuit, you can add Resistor to the HFSS component with Terminal/port. You can find the voltage accross the Resistor and series current in Ansys circuit using Voltge and Current Probes to compute the power loss.
Hope this helps,
Thanks.
