Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Convergence and Adaptive Mesh Refinement on PostProcessed Data › Reply To: Convergence and Adaptive Mesh Refinement on PostProcessed Data
September 19, 2024 at 12:12 pm
Hi Akizuki,
In HFSS, you can add the convergence based on peak gain, output variables or any other quantity.
To do so, go to 'Setup' inside project Manager. This should open a Driven Solution Setup dialog. Click on 'Expression Cache' button.
Then you click Add... to add a desired quantity in convergence
Else please refer the HFSS help PDF and section titled "Specifying Expressions for Adaptive Convergence"
Thanks,
