Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Select a curve for creating tube script › Reply To: Select a curve for creating tube script
September 19, 2024 at 5:58 am
So here you need to make changes the following changes and try.Â
Ensure that you can in 3D mode before running the script.Â
curveSelList = Selection.Create(GetRootPart().Curves[0])
result=TubeBody.Create(curveSelList,MM(5),ExtrudeType.Add)
You can also make the selection with the help of Curve Selection commoand.Â
curveSelList = CurveSelection.Create(GetRootPart().Curves[0])
Regards
Atharv
