Ansys Learning Forum Forums Discuss Simulation Preprocessing Load Key value for SFE command Reply To: Load Key value for SFE command
dlooman
Would it be possible to overlay the surface with surface effect elements, surf152, using esurf and then apply the heat flux to the surface effect elements (which only have one face)?  I don't see any way to specify the unknown face number and I know that the SF command will only apply a heat flux if all the nodes of a face are selected.Â
