Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Unattended (silent) installation of 2024R2 & -productfile switch › Reply To: Unattended (silent) installation of 2024R2 & -productfile switch
Here is a link to the silent installation documentation https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v242/en/installation/win_silent_op.html which includes syntax and informatino on options
for the stalling of the silent installation ...
- Â Does eliminating the space in the folder name yield any different results ? i.e. changing "ANSYS ANSYS 2024R2" to "ANSYS_ANSYS_2024R2" ? Or perhaps map the UNC share as a drive letter and try again ?
- Â the next set of files to be extracted might be one of these zip files (my example uses F:\ as the mount). Do any or all of these files exist in your media ?
 Extraction: F:\cads\cadregistry\WINX64.7z ...
 Extraction: F:\apipsrv\WINX64.7z ...
 Extraction: F:\syscplg\WINX64.7z ...
 Extraction: F:\mechsrvplg\WINX64.7z ...
 Extraction: F:\icemwb\WINX64.7z ...
 Extraction: F:\cads\acispara\WINX64.7z ...
 Extraction: F:\sec\WINX64.7z ...
 Extraction: F:\cads\fusion\WINX64.7z ...
 Extraction: F:\cads\spatialiop\WINX64.7z ...
 Extraction: F:\fluentc\WINX64.7z ...
 Extraction: F:\fluentm\WINX64.7z ...
 Extraction: F:\fluent3ddp\WINX64.7z ...
 Extraction: F:\tp\mpi\WINX64.7z ...
 Extraction: F:\ansys\WINX64.7z ...
 Extraction: F:\data\DATA.GZ ...
 Extraction: F:\aas\WINX64.7z ...
 Extraction: F:\cads\stride\WINX64.7z ...
 Extraction: F:\cads\hoops\WINX64.7z ...
 Extraction: F:\geompara\WINX64.7z ...
 Extraction: F:\artemis\WINX64.7z ...
 Extraction: F:\post\WINX64.7z ...
 Extraction: F:\fluent3d\WINX64.7z ...
 Extraction: F:\ensight_components\WINX64.7z ...
 Extraction: F:\tp\cpprestsdk\WINX64.7z ...
 Extraction: F:\chemkin\WINX64.7z ...
 Extraction: F:\forte\WINX64.7z ...
 Extraction: F:\icemcfd\WINX64.7z ...
 Extraction: F:\turbogrd\WINX64.7z ...
 Extraction: F:\cads\acad\WINX64.7z ...
 Extraction: F:\cads\cat5\WINX64.7z ...
 Extraction: F:\cads\datakit\WINX64.7z ...
 Extraction: F:\cads\osm\WINX64.7z ...
 Extraction: F:\cads\pe\WINX64.7z ...
 Extraction: F:\cads\ai\WINX64.7z ...
 Extraction: F:\geomunig\WINX64.7z ...
 Extraction: F:\cads\nx\WINX64.7z ...
 Extraction: F:\cads\revit\WINX64.7z ...
 Extraction: F:\cads\se\WINX64.7z ...
 Extraction: F:\cads\sw\WINX64.7z ...
 Extraction: F:\speos\WINX64.7z ...
 Extraction: F:\speosnx\SNX2212_WINX64.7z ...
 Extraction: F:\speosnx\COMMON_WINX64.7z ...
 Extraction: F:\speosnx\SNX2306_WINX64.7z ...
 Extraction: F:\speosnx\SNX2312_WINX64.7z ...
 Extraction: F:\speosnx\SNX2406_WINX64.7z ...
 Extraction: F:\additive_cl\WINX64.7z ...
 Extraction: F:\matcal\WINX64.7z ...
 Extraction: F:\motion\WINX64.7z ...
 Extraction: F:\sherlock\WINX64.7z ...
 Extraction: F:\soundsas\WINX64.7z ...
3. If not then, which media is being used to install Ansys? Were the .iso images downloaded, then MD5 checksum checked for the .iso and extracted to the share ? Or was a certain zip file or zil files used ? - which one ? if you try to install on a test machine from the GUI then does it work corectly or stalls at the same point ? it is possible that some file may be missing ?
4. Another possibility if if a security software such as an antivitus is causing access issues and hence the lockup ?
hope this helps
