Ansys Learning Forum › Forums › Installation and Licensing › Ansys Gateway powered by AWS › Could you provide the procedure to run Ansys Structure V241 on Linux VDI. › Reply To: Could you provide the procedure to run Ansys Structure V241 on Linux VDI.
Masataka Nakamura
Hi JADHAVR, Thank you for reaching out. Currently Ansys Gateway does not support deploying Ansys Structure V241 on Linux VDI. If you want to use Ansys Structure V241 on a Linux VDI you will need to install it manually.
