Ansys Learning Forum Forums Discuss Simulation Photonics Calculation of correlation values in laser modulation bandwidth simulation Reply To: Calculation of correlation values in laser modulation bandwidth simulation
susu
So for other semiconductor laser structures,are the calculate rates on the same as the default values? or I should claculate the rate of a semiconductor laser with different materials ? Thank you for your help.
