Ansys Learning Forum Forums Discuss Simulation LS Dyna Brace members penetrating into legs Reply To: Brace members penetrating into legs
ArchEng
Found the problem.
The geometry was faulty with significant gaps between the brace and the leg members. This was preventing the "bonded" contact from keeping the two members glued / welded together as it should have.
Increased the “maximum offset” of all the members with such problematic contact regions to a value greater than the gap and it works perfectly.
All members display the welded/bonded behaviour now, as they should.
