Ansys Learning Forum Forums Discuss Simulation 3D Design Lower the minimum length than 50nm Reply To: Lower the minimum length than 50nm
dkook3
Yes, in mechanical. So based on what I understood, instead of scaling the part at "Geometry", I can scale the part at "model" and then mesh, or mesh and scale the part at "model". Also, "solver" that you are saying means "component systems" in the window. I will eventually put "model" into "steady-state thermal" so if the scaling only supports on there, I can also do it there.
