Ansys Learning Forum Forums Discuss Simulation Photonics Import material .txt file with script Reply To: Import material .txt file with script
tim.fuhrmann
Thank you for your reply.
I am using the complex data. However, I have the following problem, when using the setmaterial function:
  • My data has three columns: wavelength, real part of the index, and imaginary part of the index
  • setmaterial with the property name "sampled data" only takes 2 or 4 inputs.
  • If I use only two,I don't get the imaginary part, if I take 4, even though I have only 3 in my data set (I set the last column to zero), I get wrong material parameters
Thank you for your help and best regrds,
Tim
