Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Lower the minimum length than 50nm › Reply To: Lower the minimum length than 50nm
It will collapse as you're well below the CAD kernal tolerance limits. Which solver are you using to need a volume that's 10nm thick?
