Ansys Learning Forum Forums Discuss Simulation Electronics Demagnetization setting in Direct on-line start machine Reply To: Demagnetization setting in Direct on-line start machine
Timos
Yes, the steps you're following are correct for accurately simulating demagnetization. Defining the BH Curve in the magnet material, enabling "compute demagnetized operating points" calculation and applying a desired current is all you need. This procedure should work as for a direct on-line start machine as it does for a variable flux machine.
