Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Negative torque › Reply To: Negative torque
Timos
Hello, the reason you're getting negative torque is likely due to the misalignment of the rotor angle with the dq axis. To change it to positive, adjust the initial rotor angle in Motion Setup>Data so that the rotor d-axis is aligned with Phase A negative axis.
