Ansys Learning Forum › Forums › Discuss Simulation › Photonics › far field projection of gaussian beam › Reply To: far field projection of gaussian beam
September 16, 2024 at 1:51 am
Attached is the field plot of the source and config. Currently my source span is roughly 6 beam waist radius. I tried increase the source span to 10 beam radius, and had the same problem. The plots I showed earlier was from a 2D freq monitor ~10 um above the injection plane. I also attached a screenshot of part of the layout and the monitor's visualiztion in the gui
Thanks,
Yuqi
